Ignition lights not working
Right for some reason my ignition lights r not workin, the bat,oil pressure, and hand brake light have just stopped workin, r they fused?
and any1 got a idea why?
so i wouldnt risk driving it until its sorted
Thanx fella thats really good to know
ive managed to solve the issue now,
What was it then ?
As a emergency measure if the alt/warning bulb fails just start engine and rev it past about 3500 and it will most likely kick in, but if not just touch a LIVE supply onto the IND terminal where the warning light wire goes, this will start the charge process, once started will stay until engine stops.
CabrioTurbo
Aug 1, 2015 11:04 AM
