p8 ecu wiring pins
Old Jun 24, 2008 | 10:29 AM
YBT200's Avatar
YBT200
Default p8 ecu wiring pins
hi, does anyone got a diagram showing pin numbers for escort coswort p8 ecu please.
Old Jun 24, 2008 | 10:34 AM
Dave Henshall's Avatar
Dave Henshall
the pinouts are exactly the same for a P8 as a L8 for all intens and purposes...
Old Jun 24, 2008 | 10:50 AM
Bomber's Avatar
Bomber
There is a L8 on here: http://www.siipicossu.com/manuaaleja/manuaalit.htm
As well as a load of other manuals
Old Jun 25, 2008 | 02:44 PM
YBT200's Avatar
YBT200
any better ecu pins explanation?
Old Jun 25, 2008 | 07:21 PM
Dave Henshall
http://www.tempra.org/ttt/uploads/iaweng.pdf
th last page has a wiring diagram that shows all the components in a clearer way than the ford diagram.
the last but 1 page shows the pin outs at the ecu multiplug, again clearer than the ford diagram,
Old Jun 25, 2008 | 07:26 PM
THE RADMAN's Avatar
THE RADMAN
try this one
Pin 1 - Earth (brown)
Pin 19 - Earth (brown)
Pin 2 - Lambda sensor (brown/white)
Pin 20 - Power (red)
Pin 3 - Crank position sensor (brown/yellow)
Pin 21 - Not used
Pin 4 - Crank position sensor (green/red)
Pin 22 - Knock sensor (blue/yellow in shielded cable)
Pin 5 - Distributor phase sensor (green/yellow)
Pin 23 - Distributor phase sensor (black/red)
Pin 6 - Knock sensor (black/yellow with brown earth from shield)
Pin 24 - Pin 3 Ignition module (Black)
Pin 7 - Canister purge valve (brown/white)
Pin 25 - Pin 6 Ignition module (black)
Pin 8 - Electronic control loom (blue/white)
Pin 26 - Not used
Pin 9 - Connected throttle pot wire (Pin 30 red) (white)
Pin 27 - Electronic control loom (blue/yellow)
Pin 10 - EFI power relay pin 85 (relay 8) in fuse box (plug M3BB at fuse box) (blue/yellow)
Pin 28 - Fuel pump relay pin 85 (relay 9) in fuse box (plug M5B at fuse box) (blue/gree)
Pin 11 - Map sensor (shielded) and link to common connection* (brown/green)
Pin 29 - Coolant temp sensor (black/green)
Pin 12 - Not used
Pin 30 - MAP sensor and throttle pot sensor (red)
Pin 13 - Octane adjust (black)
Pin 31 - Air charge temp sensor (red/green)
Pin 14 - Octane adjust (black)
Pin 32 - Injector 2 (brown/black)
Pin 15 - MAP sensor (black/red)
Pin 33 - Injector 3 (brown/black)
Pin 16 - Boost valve (brown/yellow)
Pin 34 - Idle speed control valve (brown/yellow)
Pin 17 - Throttle pot sensor (black/red)
Pin 35 - Injector 1 (brown/black)
Pin 18 -Injector 4 (brown/black)
*Pin 11 (brown/green) connects to the following....
Coolant temp sensor
Throttle pot sensor
Aircharge temp sensor
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
TPM961
Jan 15, 2018 10:50 AM
Nov 1, 2015 06:53 PM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
