Facelift saph cossie dash fixing positions,where are they all ??
Old Jun 21, 2008 | 07:01 PM
KSA-Cossie's Avatar
KSA-Cossie
Default Facelift saph cossie dash fixing positions,where are they all ??
Any pics too ?
Old Jun 21, 2008 | 07:20 PM
STUCOS's Avatar
STUCOS
On the bulk head,you taking dash out lol
Old Jun 21, 2008 | 09:02 PM
dojj's Avatar
dojj
Resident Wrestling Legend
there are 7 from what i can remember
once the instrument cluster is out you've got 2 behnd that
one on one of the vents on the drivers side by the switches
one underneath that
one underneath the centre vents
and then there is a clip behind the centre vent that WILL break if you don't unscrew it first
this requires a lot of dexterity and i may have a spare one i can take a pic of in the morning to show you exactly how much of a fucker it is
Old Jun 21, 2008 | 09:05 PM
xr4x4rs's Avatar
xr4x4rs
thats just for the clock surround what dojj has said
the rest you ned to cpmpletly remove all lower dash panels, include centre console as there is 2 by that
then its just the 3 on top, and 1 underneath at each end of the dash board, carnt miss them
Old Jun 21, 2008 | 09:07 PM
dojj's Avatar
dojj
he might mis the ones tucked into the bottom of the a pillars
Old Jun 21, 2008 | 09:12 PM
STUCOS's Avatar
STUCOS
Takes about 20 mins to get out mate,what you thinking of
cheeRS stu
Old Jun 21, 2008 | 09:31 PM
KSA-Cossie's Avatar
KSA-Cossie
Got a squeaking dash around about where the middle/middle left is,doing my head in.
Old Jun 21, 2008 | 09:36 PM
Csm's Avatar
Csm
Kev its a fookin sierra dash ...............it was supplied from ford with that as standard
Good luck biscuit ersed jizz bucket
Old Jun 21, 2008 | 09:38 PM
KSA-Cossie's Avatar
KSA-Cossie
I know i know Ya walloper.
Old Jun 21, 2008 | 09:44 PM
STUCOS's Avatar
STUCOS
Expanding foam
Old Jun 21, 2008 | 09:47 PM
KSA-Cossie's Avatar
KSA-Cossie
Shut up ya daftie,threadlock on the screws a bad idea ?
Old Jun 21, 2008 | 09:50 PM
Csm's Avatar
Csm
Exspanding foam ..................... lol thats a old vauxhall dash cure aswell lol
seen plenty mrk 2 astras and novas with this special mod
Old Jun 22, 2008 | 09:00 AM
turn the radio up
Old Jun 22, 2008 | 10:31 AM
Daviet's Avatar
Daviet
if you get the little sticky foam draft excluder things that go down edge of doors just stick that along the inside edge of dash takes most of the squeeks away.done this with my old xr2 and was sooo much better.or just put little rubber pads next to were you screw to dash and just stops the plastic rubbing and squeeking.
Old Jun 22, 2008 | 06:48 PM
KSA-Cossie's Avatar
KSA-Cossie
Nice wee tip davie cheers pal.
mike elsome
Sep 14, 2015 04:08 PM
dojj
28
Sep 11, 2015 10:00 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
imnoteasy
Sep 7, 2015 09:26 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
