boost control
Old Jun 21, 2008 | 05:05 PM
Gary Osborne's Avatar
Gary Osborne
Default boost control
right then , can somebody explain to me how my hks evc3 is supposed to contol its boost?
my old amal valve had one pipe to compressor, one pipe to wastegate and the last pipe venting to atmosphere , which i can totally understand.
but my hks has a pipe to wastegate , a pipe to compressor and the last pipe to the inlet after the throttle plate??
just wondering how its bleeding air off when the last pipe is on the inlet, surely it is seeing pressure here too??
Old Jun 21, 2008 | 05:20 PM
foreigneRS's Avatar
foreigneRS
Testing the future
as you say, when on boost on an open throttle there will be the same pressure in 2 of those ports
that's not to say that it doesn't control boost by how much it bleeds on to the actuator though. i'm pretty sure you can download a manual for it.
Old Jun 21, 2008 | 05:54 PM
Gary Osborne
i have downloaded the manual and am 100% sure about the pipes.
really fecking confusing me now
Old Jun 21, 2008 | 06:44 PM
foreigneRS's Avatar
foreigneRS
Testing the future
if that is how they are supposed to be connected then, it's working in reverse to the standard cossie boost control valve. it will be controlling the pressure that is bled on to the actuator, rather than bleeding off
Old Jun 22, 2008 | 06:50 PM
Gary Osborne
i can kind of guess what your saying but why does it need two pressure inputs?
Old Jun 22, 2008 | 07:19 PM
Jamz's Avatar
Jamz
It doesn't, the pipe that goes back to the inlet it where the bled air goes. On cars with airflow meters the already metered air that gets bled off has to be fed back into the inlet or the fueling will be off.
Note: there is a possabilty I could be wrong
Old Jun 22, 2008 | 08:10 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i don't understand that either, and can't believe that it should be plumbed up like that.
Old Jun 22, 2008 | 08:26 PM
Gary Osborne
ah fuck it, who cares, was just curious thanks for the inputs though
it seems to be working but its a bit of a pain as its a 2bar max controller
and if it overboosts even slightly , it then shuts down and only gives you whatever boost the actuator can hold, and takes a few seconds before it resets itself to try again.
i suppose in theory its a good system but as io want 2 bar held i think ill have to chnge it for a bigger version
Old Jun 22, 2008 | 11:51 PM
SS1's Avatar
SS1
http://www.scoobynet.com/archive/index.php/t-55357.html
Old Jun 23, 2008 | 08:23 AM
foreigneRS's Avatar
foreigneRS
Testing the future
having read the manual, i've seen that the valve has 3 ports so that it can be used with a twin port external wastegate so it needs a 3 port valve. when using it with an actuator with only a single connection, you need to do something with the 3rd port otherwise you would have a boost leak. simple as that i think.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
