What spark plugs?????
agreed but at £2 per plug you can afford to change them until you get a good set, I have seen one dodgy plug out of the 20 or so that I have bough and that was totally faulty. I would guess the missfire plugs need re gapping.
hot running plug, and was the probable cause of my meltdown,i used them after being incorrectly advised on plug choice.
071c is a good safe plug, but i have found they dont idle aswell as others....
im opting for iridiums this time i reckon
Yeah dont need any problems like that so will seek advice
I think mines in need of another set as the car started spluttering like fook when i dropped it off at the bodyshop on Thursday, it's done under 200 miles since my setup at MSD and the plugs all together have been in since the rebuild 1500 miles ago.
The car currently has a set of ford O71 in it are these good enough for 21psi??
I ran mine at 36psi no problems
Thats good enough for m, i've just bought a set off Mr Lewis.
Will the plug gap need doing on the new plugs, i'm new to the Yb engine so all the advice is widely welcome
Ok i bought some 071c's and some denso ik31's, off to the ring so dont want problems, wiil fit the ik31's and keep the others as spares, may try both to see which work the best, thanks for the advice, lee
Cheer's for all the imput guys, im gonna try a set of 071's i think, i was told to gap them at 0.8 so will cut them down to 0.6, maybe why i've been getting a missfire at full boost.
deathrider666
Sep 28, 2015 06:12 PM
