can 4wd rear diffs fit 2wds?
Old Jun 21, 2008 | 01:06 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default can 4wd rear diffs fit 2wds?
i know there slightly different can you adapt them to fit?
Old Jun 21, 2008 | 01:10 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Yes, they bolt straight in but you will need a spacer between the diff casing and beam on one of the top fixings. It's about 13mm wide. You will also need to fit 4x4 shafts and outer flanges.
Old Jun 21, 2008 | 01:43 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
as said,but just change the diff flanges to 2wd ones.easy to do.just remove the back cover,remove the c clips,and out comes the flange.
Old Jun 21, 2008 | 01:51 PM
BigErn's Avatar
BigErn
Is there any specific benefit from doing this?
Old Jun 21, 2008 | 04:33 PM
Jasesapphy's Avatar
Jasesapphy
no
Old Jun 21, 2008 | 04:51 PM
costina's Avatar
costina
Live long and prosper!!
4X4 ones seem to be cheaper then the 7.5" 2wd one. And there also found in later xr4x4's(with a slight difference in ratio)
Paul
Old Jun 21, 2008 | 05:01 PM
foreigneRS's Avatar
foreigneRS
Testing the future
weight reduction and fuel saving - it will break meaning you don't drive it
Chas
Sep 21, 2015 08:57 PM
155lee
Aug 14, 2015 11:21 AM
track.focus'd
Aug 12, 2015 05:53 PM
xr4x4rs
Aug 6, 2015 09:03 PM
lockie
Jul 31, 2015 10:03 PM
