Starter motor problem
Old Jun 19, 2008 | 09:30 PM
Series1Dry's Avatar
Series1Dry
Default Starter motor problem
Jumped in the S1 tonight and when i turn the key so the ignition lights come on, the starter motor is making a scraping noise.It starts fine when doing this and it stops after a couple of hundred yards of driving. I presume it is sticking. Do they have a solenoid ? Would this solve it or is a new starter motor ? cheeRS
Old Jun 19, 2008 | 10:02 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
just replace it easier!be careful of using it, it might be mashing up your flywheel teeth!
Old Jun 20, 2008 | 08:37 PM
javierant3's Avatar
javierant3
Hello, the starter motor has a solenoid in it. Mine was also problematic, and I dismantled it and give a clean. Now it is like new, very smooth at operation, and quieter.
Old Jun 22, 2008 | 07:30 AM
Series1Dry's Avatar
Series1Dry
Decided to put a new one on. Only £53 exchange so worth it for piece of mind. cheeRS
cossie362
Oct 11, 2015 03:53 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
