Brake lines for brake conversion
Ive just bought a set of rear 300mm discs with the remounting brackets for the calipers for my Escort Cosworth
problem is ,I didnt get the longer braided flexis with them, how long do they have to be, and who sells them or makes them up
Any advice would be appreciated
cheeRS
cheeRS
I just bought and fitted a six piece set of goodridge braided brake lines.
Two for the front.
Two for the chassis to the rear arms and
Two for the rear arms to the calipers.
They were a bob on fit for the rears as I too run a 300mm conversion on the rear.
They are no longer than 6" from memory, i'll measure then tomorrow if you would like.
Two for the front.
The Enigma
Sep 12, 2015 10:12 PM
