Speedo not working
Old Jun 15, 2008 | 12:51 PM
Tev's Avatar
Tev
Default Speedo not working
Right i need help!
my speedos not working, it packed up the other week on route to scotland,
It hasn't done the usual and dissconected its self from the gear box, or snapped the cable, so it looks like it may b a problem with the speedo dive in the gearbox, any1 ever had this happen to them? and can u still but the drive thing from ford
Old Jun 15, 2008 | 02:03 PM
LHD220Turbo's Avatar
LHD220Turbo
Originally Posted by Tev
Right i need help!
got the exact same problem with mine at the moment; its connected correctly in the box and correctly connected at the back of the dials. Luckily i have a spare drive so i'll let you know how i get on
Old Jun 15, 2008 | 04:57 PM
Tev's Avatar
Tev
cheers fella
Old Jun 15, 2008 | 05:00 PM
AndyPen's Avatar
AndyPen
Mine packed up as it had a tight spot in it. Thought I had fixed it then it would jam again.
I got another one and swapped speedos after correcting the milage to match my cars. Was quite straightforward
Old Jun 15, 2008 | 05:10 PM
Tev's Avatar
Tev
my speedos working fine, i attached a cordless drill to the speedo cable to check everthing was how it should b
Old Jun 15, 2008 | 09:11 PM
AndyPen's Avatar
AndyPen
Good news that - Hows the cable then mate - at all hot near the turbo?
Old Jun 16, 2008 | 05:11 AM
Matt Lewis does cables if needed, 01922 692424.
Old Jun 16, 2008 | 09:52 AM
Tev's Avatar
Tev
cables absolutly fine fella
Tev's Avatar
Tev
cheers tab
Tinshaw
Aug 4, 2015 09:16 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
Escortdriver1
Jul 31, 2015 02:36 PM
