Time for a oil cooler?
I think the oil is getting too hot - high revs it smokes a little - I had a look a couple of days ago after a drive - gave it a little tickle using the throttle cable - and smoke was coming out from the top of the breather on the oil catch tank.
Would this suggest it's getting too hot? I don't want to to sound an obvious question, but would a modine/oil cooler sort this?
Ideas?
Thanks.
Ideas?
Thanks.
cant really tell from that TBH mate,
sounds like its just breathing, spend a few quid on a oil temp gauge first.
i think ideally you wanna see 105 - 110 deg C, at most (on track i spose),
after that the oil becomes less effective, but under 80ish and again, the oil
dont get round quite as good!
them Zetec SEs are known for piston rings aint they? so it might well 'breathe heavy' ?
Edit: yes mate pressure is different for different types of engine.
No probs - will order some new goodies for it then I guess.
Might be worth going for pistons and rods at the same time while it's apart.
the two 1.6 zetec se engines i had only got about 10-12psi oil pressure when hot. Valve stem seals are also a weakness, mine used to smoke like dot cotton on the over run, and it did that for about 60k miles. I wouldnt be getting too concerned unless it starts smoking lots.
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
