changing cams in std head...?
Old Jun 11, 2008 | 07:37 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
Default changing cams in std head...?
.......cant ever remember reading on here if u can use/put bigger cams in a std head.........inlet side i would change,but will it be any better without porting the head.....(my pistons are pocketed).......cheers pete...
Old Jun 12, 2008 | 04:18 AM
pete mcrash
....sorry for being a dumass..........but u can reply ya know............
Old Jun 12, 2008 | 04:58 AM
R5FORD's Avatar
R5FORD
im sure people would if they were awake
or than again maybe they dont like you
Old Jun 12, 2008 | 05:00 AM
Yes as you have pocketed pistons you can stick "bigger" cams in it like BD14 inlet for example, obviously you would gain more benefit if the head was ported etc, but they are pretty good as std and you will see a big difference when fuelling is adjusted to suit the new cam.
Old Jun 12, 2008 | 05:26 PM
pete mcrash
.....cheers tabz............up again for the night time fuckers
Old Jun 12, 2008 | 06:45 PM
pete mcrash
front page.................
Old Jun 12, 2008 | 06:47 PM
Edmund's Avatar
Edmund
std cams are good for around 420bhp to go bd14 youd need ideally double valve springs,so head off and while your there a mild port with a std exhaust cam and on the T38 a solid 450bhp.
Old Jun 12, 2008 | 06:57 PM
pete mcrash
.................cheers
Old Jun 12, 2008 | 07:00 PM
BigErn's Avatar
BigErn
Sounds like a plan Pete
Old Jun 12, 2008 | 07:06 PM
pete mcrash
.......wouldn't bother with a mild one Ian................i'd go for 500+..................but then the extra of transmission upgrades............doh
Old Jun 12, 2008 | 07:19 PM
BigErn's Avatar
BigErn
Do it. I dare ya
Just dont launch it and it should last a little longer, might give you a chance to save up for transmission.
IainRS1700T
Sep 25, 2015 06:44 AM
dombanks
Sep 21, 2015 08:38 PM
focuspower
Sep 20, 2015 03:51 AM
CrOwSoN15
Sep 14, 2015 11:33 AM
marky_g
Sep 12, 2015 04:26 PM
