(Screamer pipe) F.A.O Christian
Old Jun 9, 2008 | 04:35 PM
Billy_RS's Avatar
Billy_RS
Exclamation (Screamer pipe) F.A.O Christian
Thinking of getting the turbo elbow spilt into two chambers.
One for normal exhaust gas and seperate for the wastegate.
I think christian had one, just wanted to know how to approch it. I have a machinist down the road and he is capable of pretty much anything.
Old Jun 9, 2008 | 04:52 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
Christan has an external waste gate I believe, don't think he lashed it together.
Old Jun 9, 2008 | 05:29 PM
Billy_RS's Avatar
Billy_RS
No before he had the external gate. Unless im getting confused.
stuart collins's Avatar
stuart collins
why do u want 1 or need 1
Old Jun 10, 2008 | 08:17 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I did several years ago try a system where I made an exhaust which divided the turbine from the wastegate, using an internally 'gated turbo. I ran a screamer pipe, which was neat for about 5 minutes, then just became annoying. It was infact a Pulsar turbo.
In reality there is a technical reason why this is a bad idea on an RST, but I won't bore you with that.
Old Jun 10, 2008 | 09:28 AM
Turbocabbie
Top Cab !!
Please bore me with that... if I never learn't anything I would still be running a bleed valve and dump valve and im curious now
Old Jun 10, 2008 | 10:00 AM
Christian and Beccy
#1 in Spelling Club
It's really hard to explain, but when you have the wastgate flap openging horizontally, but the flow passing through it vertically, as it does on an RST, then you divide the wastegate, the flow will be restricted and you get boost creep. It's SO much easier to explain face-to-face!! LOL.
Basically, the wastegate only opens a small amount and it needs all the room it can get inside the turbine housing and by dividing the wastegate from the turbine housing, you restrict the room it has to flow.
Complicated eh?
Old Jun 10, 2008 | 10:07 AM
cressy's Avatar
cressy
Complicated eh?
that old chest nut?lol
Old Jun 10, 2008 | 10:20 AM
Christian and Beccy
#1 in Spelling Club
PMSL.
Old Jun 10, 2008 | 03:16 PM
Billy_RS's Avatar
Billy_RS
ok, first and only reason is the noise!
I'm running a bar of boost, mate of mine has one on his skyline gtst. It sounds awesome.
I dont wanna use external gate as its far past my needs, so really just want it to sound mental!
Childish... Yes. But i dont care.
Christian, do you have any photos or the actual elbow still?
Cheers for the info on the boost creep, i didn't realise it would have a negative affect.
Cheers.
Cosnada
Jan 7, 2016 05:30 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mpilk
Sep 27, 2015 09:21 AM
