stickin rev counter
Old Jun 8, 2008 | 05:15 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default stickin rev counter
hi recently put in a new set of dials in me series 2 and my rev counter is stickin? what has caused this?
Old Jun 13, 2008 | 04:14 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
prob pushed the needle on to far so its stuck on the face!!!
Old Jun 13, 2008 | 09:26 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
thing is it moved then got stuck now it dont work? what the fuck?
Old Jun 13, 2008 | 10:35 PM
orion_crazy_carl
orion=mini saff
try pulling the needle off a bit
Old Jun 14, 2008 | 09:10 AM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
ill give that ago.
the rev counnter works by the wired plug doesnt it?
Old Jun 14, 2008 | 09:35 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
It's the good-taste fairies little way of telling you that you should leave the dials standard.
Old Jun 14, 2008 | 02:08 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
i bought a setof lockwood dials of a mate in white they worked, now rev counter dont that well
Old Jun 14, 2008 | 02:14 PM
orionmojo's Avatar
orionmojo
do as carl said, and try and take the needle of a touch, they're also spring loaded, and if you plonk it straight on, it wont read right. you need to put it on slightly lower than the resting pin (but oly a little bit) then "bend" the needle over the pin so it sits on it when not in use.
Old Jun 14, 2008 | 02:15 PM
orionmojo's Avatar
orionmojo
but they peel and look shite!
Old Jun 14, 2008 | 10:26 PM
Chris69's Avatar
Chris69
they don't all peel and look shite, if you want console that still looks as new pm me- i have a couple spare
Old Jun 17, 2008 | 10:10 PM
orionmojo's Avatar
orionmojo
i'm ok mate thanks, i got white ones
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
