"Grp A" Coil question . . .
Old Feb 5, 2004 | 03:28 AM
Default "Grp A" Coil question . . .
What do you do with the two wires that plug into the standard coil?
The Group A coil has four flat leads - do you use just two of the connectors? Or split into four?
Thanks!
Old Feb 5, 2004 | 06:44 AM
i just used 2 of the connectors but i have seen some people split them into 4
i couldnt tell you if that makes any difference though
Old Feb 5, 2004 | 04:11 PM
Thanks for the reply - I'll just use the two.
Old Feb 5, 2004 | 04:26 PM
Toe Knee's Avatar
Toe Knee
AS said, i just used 2 aswell with no problems!
Old Feb 5, 2004 | 11:34 PM
Sorry to hijack but did you notice a difference putting on the group A coil? i got told they don't make that much difference! More power? Better fuel ecconomy?
Ta,
Old Feb 6, 2004 | 09:05 PM
As Mr Cossie 4x4 said, have you people using these coils noticed any improvements? I'm thinking about upgrading the ignition on my cossie, am just wondereing if its worth it.
I also apologise for jumping on your thread.
Old Feb 8, 2004 | 01:36 AM
Well I put the coil on and drove it tonight - it does seem to pull harder now and smoother in acceleration, also seems to boost quicker. In my car it is an improvement. I'd say it's worth it.
cheers
Old Feb 8, 2004 | 11:58 AM
DazC's Avatar
DazC
Less chance of the spark being blown out with the Group A coil...
Old Feb 8, 2004 | 09:13 PM
DazC, thats the problem i've got at the mo. I having to gap the plugs to .4 of mm to stop it happening so i might invest in a group A coil.
Old Feb 8, 2004 | 09:35 PM
Stu @ M Developments's Avatar
PassionFords Creator
.4mm?
No, you need to fix the problem TBH mate, and you deffo DO have one.
Unless of course the problem "IS" your coil, then it may fix it
Old Feb 8, 2004 | 10:08 PM
DazC's Avatar
DazC
.4mm? Are your leads ok? Have you got good voltage to the coil? A Group A coil is a worth while investment anyway.
Old Feb 9, 2004 | 02:31 PM
Toe Knee's Avatar
Toe Knee
As said didnt notice an amazing difference BUT its more a peice of mind that they geenrate a better spark than standard thus reducing the chance of miss fireing due to a weak spark, for the price its worth the peice of mind
Old Feb 9, 2004 | 08:58 PM
Are the two pairs on the Grp A coil two positives and two negatives or is there one of each on both posts. Just bought one too and dont know how to wire it.
When i bought it the guy told me you have to buy a special mini loom with a relay in it to get the full benefit of it :-( Didnt tell me that until afterwards though!
ss
Old Feb 9, 2004 | 09:21 PM
Toe Knee's Avatar
Toe Knee
Both on 1 are posi, both on the other are neg, ive just cut the push on connectors off and used insulated spades on mine on 1 of each and it works fine, if you get a proper conector that can fit too both and make it water tight it would obviously be better but havnt noticed any problems as of yet!
Old Feb 10, 2004 | 11:27 AM
Thanx for letting me know guys, I'll go and get one now
Old Feb 22, 2004 | 09:23 AM
kjc300's Avatar
kjc300
Is it pos at the top or bottom!!!!!????
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
A.t.p
Sep 29, 2015 05:04 PM
