alternator wiring diagram or info/
my mates rs turbo battery light is constantly on (bought it like this)and the battery isnt charging. its had a new alternator and battery. we unsure of where the wires go. we know one is sensor for dash light. but does one go to battery and othe to starter? cheers
The bulb powers the alternator by initiating the charge process, connect the thick wires to the alt and battery, then it should be ok, unless the alt is buggered, just touch a LIVE onto the IND terminal whilst engine is running, and this will start the charging process if ok, it would certainly appear to be as it is getting live through the bulb and earth from the alt(this IND changes to LIVE when outputting)
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
