Throttle body before the turbo?
Old Jun 6, 2008 | 02:12 PM
evo200's Avatar
evo200
Default Throttle body before the turbo?
As title peeps....
Stumbled across an American forum where they were on about mainly Pre compressor throttles on 80's F1 cars. I know renault di this with the Group B 5 Maxi too.
One fella was on about how he'd put the throttle body before the inlet to his turbo (I suppose like a draw through carb installation) and how responsive it made the engine as there was no need to run a dump valve because between gear changes the compressor wheel would be spinning unloaded in a vacuum (throttle shut) thus keeping its speed up ready for when you get back on the throttle, and no need to dump any compressed air.
http://forums.autosport.com/printthr...threadid=78714
Any thoughts? could you do this with say a T34 turbo or would the vac suck oil past the seat and into the inlet?
muffster
13
Sep 3, 2015 09:40 PM
Russ Hill
Aug 31, 2015 06:44 PM
Cosnada
Aug 27, 2015 09:15 AM
Dicko&Vacant
Aug 21, 2015 05:59 PM
M K
Aug 12, 2015 06:57 PM
