Can siemens 83lb injectors be too 'big'?
Old Jun 5, 2008 | 06:31 PM
XRT_si's Avatar
XRT_si
Default Can siemens 83lb injectors be too 'big'?
As above, looking for some Siemens Blacks to replace my greys, only need them for around the 400bhp mark.
I understand 55lb would be ideal but will 83lb be ok too? Is there a problem with them being so big? cheers
Old Jun 5, 2008 | 06:53 PM
RWD Pete's Avatar
RWD Pete
dont think so mate altho i may be corrected, dont forget fuelling needs to be good not just on full power. for example my 450+ saff on 83's fuel's nicely all the time not just on full chat.
Old Jun 5, 2008 | 06:56 PM
Twellsie's Avatar
Twellsie
i wouldnt have thought it will be a problem with the correct mapping, i run greys on a T3 with no probs at all
Old Jun 5, 2008 | 06:59 PM
DENNIS's Avatar
DENNIS
should be fine if you have an ecu that can control them well...
i have theses on my Escort with an autronic SM4, although i have lowed the fuel pressure to 3 bar static to help the idle, but even at 3bar rail pressure there only at 1% duty at idle..
but for 400 they are a bit to big really..
you would be better suited with the 55lb items..
Old Jun 5, 2008 | 07:29 PM
RWD Pete's Avatar
RWD Pete
but if you go bigger better faster in the future you have the injectors for it, and lets face it you probably will
Old Jun 5, 2008 | 07:37 PM
LHD220Turbo's Avatar
LHD220Turbo
will be fine mate if set up correctly, you might as well get the 83lb as that way you've have future proof'd the injectors in case you want to increase power later on
Old Jun 5, 2008 | 08:00 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
It really depends on the particular injector... in the case of the 'siemens blacks', then 83lb will probably be ok as they are quite manageable.. i'd go for the 55's though, would give superior control/emissions.. it's not hard to change to bigger ones in the future.
Old Jun 5, 2008 | 08:30 PM
ESCYSCOTT's Avatar
ESCYSCOTT
what about 750's??
Old Jun 5, 2008 | 09:44 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
If you decide to drop down to 55's, I have a brand spanking new set here that I didn't use.
Old Jun 6, 2008 | 08:41 AM
scoooby slayer's Avatar
scoooby slayer
be fine i have them msd mapped spot on and there good for up to 650 hp if needed
Old Jun 6, 2008 | 08:48 AM
Luca's Avatar
Luca
Lukesville
Originally Posted by ESCYSCOTT
what about 750's??
Exactly what i was thinking !
Im using 750cc injectors and thats to be with 450bhp.
If your running good managemnt though the larger ones will be ok
but maybe a little lumpy when cold.
Old Jun 6, 2008 | 04:59 PM
XRT_si's Avatar
XRT_si
I only really want it for better fuel comsumption to go with the closed loop it will be going on shortly.
Sounds like 55lb are the better options in which case.
Cheers fellas
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Nick 172 Sport
Sep 28, 2015 07:21 PM
