Brake problem
Old Jun 4, 2008 | 03:13 PM
Gregor's Avatar
Gregor
Default Brake problem
Hejj all,
Ok,
I'm having some problems with my brakes.
The pedal is hard real quickly, but they don't stop the car verry good.
Looks like the front isn't doing verry much.
Setup is cosworth 2wd callipers and disks (283) at the front with braided hoses en xr4 calipers and disks (253) at the rear.
Already changed all the pipework @ the front, reconditioned the front calipers, changed the brakeassist, changed the master brake cilinder but stil brakes like crap.
Anyone got any advice?
thanks.
Old Jun 5, 2008 | 11:15 AM
NUTS RuS's Avatar
NUTS RuS
What size is the master cylinder ?
Old Jun 5, 2008 | 11:20 AM
grayzo's Avatar
grayzo
grayzo
as above and have u bled the system through properly
Old Jun 5, 2008 | 04:59 PM
Moonie's Avatar
Moonie
Have you checked the brake servo is functioning ok?
Old Jun 5, 2008 | 08:46 PM
Gregor's Avatar
Gregor
Size of the master cilinder is standard rs turbo one.
Should i upgrade to a bigger one?
I thought the standard one would do fine but i would just have to push it a little further down.
Problem now is it get's hard pretty fast and i can push as hard as i can but it doesn't really stop verry fast.
Old Jun 5, 2008 | 08:48 PM
Gregor's Avatar
Gregor
In my opinnion i have... if it's not been bled properly it would be real soft pushing the pedal to the floor easy wouldn't it?
Old Jun 5, 2008 | 08:50 PM
Gregor's Avatar
Gregor
Haven't really checked it , did replace it for another one with the same effect.
How can i check it for working properly?
Thanks all sofar
Old Jun 5, 2008 | 10:23 PM
NUTS RuS's Avatar
NUTS RuS
Did you bleed the ABS pumps ?
What pads (make and compound) are you running ?
Tony
Old Jun 6, 2008 | 12:06 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Sounds to me like there is no servo assistance working.
Check the vacuum pipe from the inlet manifold to the brake servo for splits, one way valve working etc.
also check the diaphragm inside the servo is not split.
Old Jun 6, 2008 | 03:51 PM
Moonie's Avatar
Moonie
Thanks all sofar
As above check the vac line between the intake manifold and servo for splits etc. The one way valve is only there to prevent positive pressure entering the servo when on boost. However if this valve has stuck in the closed position then it will prevent vaccuum from reaching the servo.
The way to test the servo is - Engine off, pump the brake pedal a few times to depleat the vacuum from the servo (the brake pedal should now be solid if not there may be air in the hydraulic system somewhere). Hold your foot on the brake pedal and start the engine, the pedal should sink as vacuum builds up inside the servo.
Old Jun 6, 2008 | 05:19 PM
Gregor's Avatar
Gregor
Tony
Haven't got ABS anymore.
Pads are standard cosworth at the front and standard sierra at the rear
Old Jun 6, 2008 | 05:22 PM
Gregor's Avatar
Gregor
I've noticed no splits in the vaccuum line.
When the engine is off the pedal is hard straight away, when i fire up the engine the pedal slowly sinks 1-1.5 inch or so as you've discribed.
Old Jun 15, 2008 | 03:47 PM
Gregor's Avatar
Gregor
Anyone got any more ideas??
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
