Silly mistake. Arrived today. went to put them in the garage and one fell of the shelf.
It has this little mark on it now, will it be ok? Could it be repaired? Is this now scrap?
Doubt if that little ding has distorted anything - as suggested, get any burrs removed (if any) and it will be fine... just be careful with them when you take them
Stop worrying, just use a bit of emery to take off sharp edges, it's nothing, or bring down and I'll spin it in the lathe for you if that fussed, personally a bit of emery for me, then a good wash.
Tabetha, I may take you up on that if your ok with it.
when I touch the skirt I can feel a little imperfection.
If you are still worried just get a thin piece of wood about 1 " wide and glue a bit of emery to it then use as a flat board for taking out mark.
