diff problem
Old Oct 28, 2004 | 04:20 PM
bigal1978's Avatar
bigal1978
Default diff problem
hi there 1 of the 17 mm bolts that hold the diff mountin to the diff has fooked off
is this a bad thing or should i just change the diff
it will not take another bolt theres no threds left
Old Oct 30, 2004 | 06:05 PM
spannerman69's Avatar
spannerman69
have you tried to get it hellycoiled ,its a spring thread to replace the original that has stripped.most garage`s should be able to do this for you.
Old Oct 31, 2004 | 12:21 AM
bigal1978's Avatar
bigal1978
i have another diff i can put in but just cant bearsed to change it or fix it if it wont cause a problem
mark r
Sep 29, 2015 07:27 PM
Russ Payne
Sep 25, 2015 08:29 PM
Fezman1
Sep 7, 2015 09:34 PM
RSBryden
Sep 6, 2015 08:39 PM
