Intercooler for my setup
Old Jun 2, 2008 | 10:52 AM
Antti O's Avatar
Antti O
Question Intercooler for my setup
Hi!
I just wanna ask intercooler advice for my setup:
-1600cvh turbo
-Kent cvh 35 camshaft + pulley
-Mongoose 2.5"
-31 actuator
-standard turbo
-EFI intake manifold & megasquirt managment
Planned 15 psi / 1.0 bar of boost.
What kind of intercooler do you recommend?
How about the s2 rst standard ic, how much boost it will handle?
ps. if you have ic for sale please pm for me.
Old Jun 2, 2008 | 11:10 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
i would suggest a GRS twin pass, best intercooler available off the shelf imho
pa_sjo's Avatar
pa_sjo
Colossal Pervert
As large as you can fit and single-pass..... and preferably cut a big hole in the front bumper to get as much air through to it as possible.
Old Jun 2, 2008 | 11:14 AM
MattyRST's Avatar
MattyRST
Standard intercooler will be fine for 180bhp / 14psi, as this is what im aiming for when i take my car to motorsport developments.
Pace double i.c is fine
Airtek double
Pace front mount
Airtek front mount
GRS front mount
Old Jun 2, 2008 | 11:19 AM
Antti O's Avatar
Antti O
Thanks for advice, GRS looks fine but i am worried about the cooling of the radiator, so i would choose some smaller but larger than the standard one. Pace double capacity looks nice..
I did read that the standard ic is restrictive in air flow, is that true?
Old Jun 2, 2008 | 11:23 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Everything is restrictive, eventually. Std intercooler isn't even good enough for a Stg 1 chip - in anything other than winter air, 4/5th gear runs at 1 bar will see excessive ACT's and the ECU will start to pull timing to protect the engine (although, the turbo will get a hard time).
I am not a fan of GRS intercoolers. They are a crap fit, the twin-pass ones are very restrictive and every one I have seen has caused overheating problems (only real way to overcome that is to put the rad fans infront of the intercooler).
The nicest one i've seen and tested is the Pace one, but it's expensive (about £500 I think, with a new charge carrier etc).
Old Jun 2, 2008 | 11:55 AM
Turbocabbie
Top Cab !!
I would not be concerned, ive got one and my bumpers not cut out, I also run anti-lag and nos and have never seen worrying temps for either water temps or act
Old Jun 2, 2008 | 02:03 PM
sm's Avatar
sm
full front mount is the only option imo i run a radtec intercooler on my s1 with the fans on the front of it with no cooling issues, just make sure ur rad is in good condition, u have a good 50/50 anti freeze mix and pref a cossie stat (makes the fans kick in earlier)
Old Jun 2, 2008 | 02:43 PM
JamboRS's Avatar
JamboRS
focus rs 1672
for that boost i say the pro alloy single pass,act's will be manageable at that level
Old Jun 2, 2008 | 03:08 PM
grayzo's Avatar
grayzo
grayzo
airtec or if u want cheap cooler to do the trick a 4x4 cos cooler
Old Jun 2, 2008 | 03:12 PM
MattyRST's Avatar
MattyRST
Does a cossie cooler fit ??
Old Jun 2, 2008 | 03:23 PM
grayzo's Avatar
grayzo
grayzo
my friend has one on his series 2 its just needed minor mods
Old Jun 2, 2008 | 08:20 PM
Joe1199's Avatar
Joe1199
always try and go single pass although its maybe not always practical, we have had cars gain around 30bhp just by cutting twin pass tanks off and welding a bodged single pass system in, obviously with a developed i/c like the off the shelf ones the gains/losses wont be as bad and in my opinon single pass look so much better anyway!
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
