fuel filter
Old May 31, 2008 | 09:24 PM
hivis's Avatar
hivis
Default fuel filter
Hi all, just fitted a new fuel filter to my sapphire cos now i cant stop it leaking where the ends screw into the filter all connections are tight. Any ideas how i can stop it leaking.
Old May 31, 2008 | 09:32 PM
mechanic28's Avatar
mechanic28
these can be a royal bastard to seal!!!did u use old or new seals??
Old May 31, 2008 | 09:36 PM
hivis's Avatar
hivis
I used the old ones as i didn't get new ones with the new filter
Old May 31, 2008 | 09:46 PM
mechanic28's Avatar
mechanic28
ah ok might need new seals!although these can still leak!did u put the old seals in the exact same place?or did you swap them around???might be worth checking your pipes could be pitted and need a little clean up!
Old May 31, 2008 | 09:49 PM
hivis's Avatar
hivis
ok i will check the pipes and get some new seals thanks for the advice.
Old May 31, 2008 | 10:39 PM
mechanic28's Avatar
mechanic28
no probs!let us know how u get on!
Old May 31, 2008 | 11:39 PM
AndyPen's Avatar
AndyPen
If they are the copper washers get them red hot with a torch - well away from the car of course, then when cool you refitt them and they make a new seal. Worked for me but some people use nylon ones I'm told? The banjos can also get a bit pitted and need replacing. Pain of a job!
Old Jun 1, 2008 | 10:02 AM
LHD220Turbo's Avatar
LHD220Turbo
had the exact same problem this weekend - could not get them to seal no matter what i did.
i ended up replacing both the banjo bolts - you can get them from any hydraulic place. i also got some steel washers which have a rubber insert. This worked a treat
Old Jun 1, 2008 | 10:11 PM
Sta1n1's Avatar
Sta1n1
had the same problem, I used old seals and leaked pretty bad just fit a new copper seal and it will be fine
Old Jun 2, 2008 | 06:35 AM
The metal washers with a rubber insert are DOWTY WASHERS, these are NOT petrol resistant, unless specced as such.
The best way to reaneal old washer isheat up till red then drop in OLD engine oil, not leave to cool.
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
mondeomark
Sep 28, 2015 06:28 AM
