Actuator problems
Old May 31, 2008 | 09:14 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Default Actuator problems
Hi all, just wondering if someone may know the answer to a problem im having getting a suitable end for my actuator.
The actuator is a -31 and the turbo is a universal turbos T38.
I cant seem to get hold of the right end for the actuator as the long one i have is much too long and when it reaches the end of the thread it holds the wastegate door open.
The shorter one i have is so short that with the wastegate fully closed, its nowhere near the actuator rod!!
I could cut the rod down as some people have suggested but there must be a better way surely!
Any advice will be much appreciated!!
Old May 31, 2008 | 09:15 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Forgot to say that its on a 4x4 manifold too.
Old May 31, 2008 | 09:18 AM
Stu @ M Developments's Avatar
PassionFords Creator
Looks like the WRONG actuator mate.
Is that a 4wd turbo and manifold?
Old May 31, 2008 | 09:22 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Yes mate, the turbo came off my mates 4x4 saph with standard manifold.
Are there different types of -31 actuators?
Old May 31, 2008 | 09:33 AM
Yes mate, the one you have there is for a 2wd turbo. You will have to cut and weld those two rod ends together to make one that fits.
Old May 31, 2008 | 09:39 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
ehem. i have the oposite problem,
i have a 4x4 -31, and need a 2wd one.....
swap shop?
Old May 31, 2008 | 09:56 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Stu - Thanks for your knowledge mate! I think i'll bite the bullet and get a fourby one!! Cheers mate!
JTECHSAFF - I'm interested in a swap mate. Mines only had a couple of months use before i killed the engine!!
Old May 31, 2008 | 05:12 PM
JTECH James
Passion for Fords!
how long is the longest of the arms you have there....think i have one in between yours....which will be what you need....i need the longer one.
the actuators should be ok i reckon
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
