2wd Arb Upgrade
Old May 29, 2008 | 10:45 PM
STUCOS's Avatar
STUCOS
Default 2wd Arb Upgrade
Thinking of up grading the rear arb on my 2wd saff,is a escos one the thickest of the lot,and is it a straight replacement on a 2wd
cheeRS stu
Old May 29, 2008 | 10:54 PM
dazzle740's Avatar
dazzle740
yes mate they are all a straight swop (4b or ecose) as long as you have the appropiate bushes, i have 4b one on my saph makes a difference i think didn't go ecose cos with being 2wd i didn't want to make it to stiff and therefore scittish.
Old May 29, 2008 | 10:57 PM
STUCOS's Avatar
STUCOS
Cheers bud,will look for a 4b one then
cheeRS stu
Old May 30, 2008 | 07:18 AM
2wd is 16mm, 4wd is 18mm, escos is 22mm, and silly money s/h, hard to come by.
A SCORPIO is 21mm from a SCORPIO 24 VALVE COSWORTH, and fits straight on, the GRANADA SCORPIO COSWORTH 24 VALVE is 18mm same as 4wd cossie sapph.
The PROPER scorpio is the BUG EYE one at 21mm, just ordered one, Ł40 delivered, going to drill out the 16mm poly bushes to suit, after freezing them first of course!!
Old May 30, 2008 | 07:52 AM
LINCOLN's Avatar
LINCOLN
Great information Tabetha!!!!
Old May 30, 2008 | 08:12 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Tab,
you are so knowledageable is almost painful for mere mortals like myself to read. Top advice as usual mate
Old May 30, 2008 | 08:19 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Also, just so that you can work out the relative stiffness of them, you have to apply each roll-bar size to the power of 4 .
Eg:
16mm x 16mm x 16mm x 16mm = 65536
18mm x 18mm x 18mm x 18mm = 104976
21mm x 21mm x 21mm x 21mm = 194481
22mm x 22mm x 22mm x 22mm = 234256
104976/65536 = 1.6 . Therefore an 18mm roll bar is 1.6 times stiffer than a 16mm rollbar .
It actually sounds like the 21mm one is a better compromise to the Escort one, as 1. It is cheaper and 2. It is just under three times the stiffness of the 2wd one, compared to the Escort one which is 3.5 times stiffer.
Good find Tabs .
Old May 30, 2008 | 02:18 PM
I think my best bit was freezing the poly bushes, so they can be drilled, need a VERY SHARP bit like COBALTS though.
You can also buy POLY in RODS to lathe up and make your own bushes!!
Old May 30, 2008 | 10:03 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
it all depends on the hardness of the urethane... i've machined it on the lathe at room temperature, but it was 80 shore. used a normall drill bit too, but i had just sharpened it. its best done with some lubricant too, as it soon burns.
and don't think you're the first to discover the scorpio ARB either although it measures more like 20mm than 21
Old May 31, 2008 | 07:29 AM
I never claimed to be the first, and don't give a shit who was the first, just thought it was info others may have found usefull, so took the time out to let them know.
I don't know the exact size as do not have one in front of me to measure(yet), but of course you would need to remove the paint to get a accurate diametre.
Comments like this are why I am thinking of ditching PF.
Old May 31, 2008 | 07:35 AM
hitchwest's Avatar
hitchwest
excellent find tabs thinking of upgrading my arb too
Old May 31, 2008 | 07:38 AM
joffy's Avatar
joffy
SLOW LEARNER
Where did you get yours from for Ł40 tabs and will it be a straight fit to a three door?? changing the bushes obviously
Old May 31, 2008 | 10:20 AM
a7fco's Avatar
a7fco
dont ditch us Tabetha your knowledge is always appreciated by the majority fuck the rest.
Old May 31, 2008 | 10:28 AM
joffy's Avatar
joffy
SLOW LEARNER
for a slow learner like me that knowledge is defianetly appreciated!!
Old May 31, 2008 | 10:36 AM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Top advice, and always willing to give it. Stay here dude, majority of people are pleased to see you post.
I had a new from Ford Escos roll bar on my 4*4 Saph, made a noticeable difference for the year or so it was fitted. Also had new bushes/ brakcets at the same time.
Will be for sale shortly (not a for sale post though )
Si
Old May 31, 2008 | 11:17 AM
Paul_RS's Avatar
Paul_RS
I for one always find what you have to post very interesting and you've helped me out a few times with questions i've had. Don't let the minority put you off as you would be missed if you left passionford
Old May 31, 2008 | 12:41 PM
BRAMMER's Avatar
BRAMMER
So all the information regarding 2wd applies to us 3dr owners too?? and is the difference that noticable?? as theirs loads of scorpios in my local scrapper
Cheers.
Old Jun 2, 2008 | 08:12 AM
Mike Rainbird
Caraholic
Cheers.
No, as the 3dr rear beam mounts for the ARB are located differently, so to fit the bigger ARBs from the later cars on, you would need to weld into position the brackets from a 2wd Sapphire or 4x4 Cosworth, then it should .
Old Jun 2, 2008 | 09:16 AM
Ryan's Avatar
Ryan
or change the rear arms i pressume mike?
Old Jun 2, 2008 | 10:40 AM
Mike Rainbird
Caraholic
Yep - that would do it as well .
tankybaby66
Feb 6, 2016 02:24 PM
Fezman1
Oct 2, 2015 01:22 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Sp3no
Sep 27, 2015 07:23 PM
