Quick Sale Needed for New Cossie Engine seen a car
Seen a car i want to buy,
This engine was up for £3K
£1900 Cash before the weekend gets you
Fully rebuilt cossie engine
200 Block
ACL Race Bearings
Polished Standard sized Crank
ARP Studs
New piston Rings
10K Pistons
Arp Rod Bolts
Rods Weight Matched
Rebuilt 4x4 Head
New Seals
New Tappets
New Valves
New Guides
Standard 4x4 Cams
Only Had 1 Skim
Brand New Water Pump
Brand New Oil Pump
4x4 Inlet with new Gaskets
2wd Exhaust Manifold
Fly Wheel
ARP Fly Wheel Bolts
New water temp Sender
New Oil Temp Sender
New Air Temp Sender
New Cambelt
New Tensioner
New Head Gasket
8.1 Compression
The head is off the block and the whole engine has never turned a mile, over £3.5K Repceipts
£1900 cash by Saturday or i keep it
200 Block
ACL Race Bearings
ARP Studs
New piston Rings
10K Pistons
Arp Rod Bolts
Rods Weight Matched
Rebuilt 4x4 Head
New Seals
New Tappets
New Valves
New Guides
Standard 4x4 Cams
Only Had 1 Skim
Brand New Oil Pump
Fly Wheel
ARP Fly Wheel Bolts
New Oil Temp Sender
New Air Temp Sender
New Cambelt
New Tensioner
New Head Gasket
8.1 Compression
But could it not be a 2wd with 200 block used for making a stronger engine?
Ok I will rephrase, what sump/oil pump and oil pick up are on the engine 2wd or 4 wd.
Cheers.
2wd pump, 2wd pick up pipe, 2wd sump, 2wd engine mounts, but still have 4x4 mounts if needed.
Just been to check paper work it is 1mm bore,
I would have to get the head measured but i think it was 138.8
The manifolds have been taken off and the throttle body is in use elsewhere, will come with standard pulleys as i sold them seperate.
The cams are bubble wrapped ready to fit and all the cam caps are in place.
You will need your own front pully and water pump pulley
to be honest the hybrid engines are the best. The 4x4 has superior parts and so does the 2wd. mix them together and you get something even better The main good thing is that is has the 4x4 block and head
matman
Sep 9, 2015 05:45 PM
Graceland
Jul 31, 2015 10:34 AM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
bargain
