what suspension
im running standerd suspension at the moment and have been llooking into a 40mm spax kit.
found this gaz kit on ebay. are they any good or should i stick to the spax/koni ect.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=006
CHEERS... dan
CHEERS... dan
Wouldn't recommend them TBH. The front will be okay, but you will be putting all the sprung tension onto the rear shock top mounts and it is not uncommon for the mounting to break away from the shell with use if not reinforced.
Personally, I would only go 15-20mm drop as any more can make the ride uncomfortable, plus would look for something like Bilstein gas dampers with a reputable progressive-rate spring.
stay away from gaz coil overs m8
i have them in my car and would not recommend and also if you put coil overs in you need to go for a rear disc conversion
yeah am staying well away from them, but i have standerd suspension at the min and want to lower it 40mm.. a mate of mine has told me the SPAX kits are good or should i go for any of the other makes?
There is no connection whatsoever between running coilovers and needing a rear disc conversion
Tony
Spax are not in the same league as Koni... If you want decent dampers, then buy Koni, Bilstein, DeCarbon etc.. If you want budget crap, then buy avo/spax/gmax/other_german_brands_like_weitec
SMILER258
Sep 28, 2015 09:04 AM
