water temp to high !!! no boost
my focus as started running very little boost because the water temp is going up in the 100 ive changed the thermostat, bleeded the system so no trapped air and changed the header tank and cap and still no change
ive got a new temp switch to fit but dnt think it could be that but will see.
have anyone else had similar problems or know of anything that could help please????
cheers rsmat.
cheers rsmat.
Max temp for the FRS before the fan kicks in should be 105C
Whose FRS is that if you dont mind me asking Mark - thought it was just Paul Hamlings old FRS, mine & Kev Jones running the SM4 on the FRS so someone else has obviously gone that route as well then
whats sm4???
SM4 is this
Mark
Mark
My scangauge takes the water temperature from the sender in the block for the Ford ECU!
Everybody I know, there fans kick in @ 112 and cut out about 106!
Cruising @ 80 on a summers day on the motorway will see my temp sitting at a constant 110-112!
