cosworth management
does any one or tuner sell the modifyed parts for doing this ie off the shelf items like mfi injector rail to take greens crank possition pullys ect??
cheers
cheers
you probably want to try jano at oddkidd creations,
he does have message board but its down at the mo, link anyway:
http://www.elite-solutions.net/oddki...15fd7e1746dc1f
Got everything except ecu and injectors here!
Efi inlet modded in crackle black
modified cossie throttle body in crackle black
custom throttle bracket in crackle black
modified throttle linkage
Idle speed control valve,
efi fuel rail and regulator
ingnition amp,
new 3 bar,
new coolant sensor,
new air temp sensor,
new throttle position sensor,
crank sensor setup is at the laser cutters now, ( to retain original pulley )
camshaft sensor bits being made now,
cossie loom, already modified to suit cvh layout and recovered,
i can also get you a cossie level 6 ecu with pectel board already fitted and a chip to run greens!
will just need some gaskets, adaptor plate if keeping the mfi head and i can make new fuel lines to go with a quick release fuel filter or you can keep your original one.
also can fit for you if you need.
ingnition amp,
new 3 bar,
new coolant sensor,
No, i'm not a trader, just have loads of bits for sale, and because i've done a few jobs on peoples cars don't make me a trader lol, if someone asks me to change their oil and wants to pay me, or do a complete engine and management change, who am i to say no? i'm like everyone else, i need the money! i'm not proud!
Oh, and thanks for remembering all my posts, most kind
I wouldn't buy anything off him. Last time me and a few others bought off old Lennie he was pulling a fast one under a diferent username, parts were never sent, busted him with his postal address being the same.
Thought you got banned Lennie old boy?
You have been warned.
As said tho, go with something newer VEMS or Omex perhaps....
JK12
33
Apr 26, 2021 12:09 PM
Nov 3, 2015 04:08 PM
