My Group A spec rear beam
Old May 25, 2008 | 01:35 AM
oohogwash1's Avatar
oohogwash1
Default My Group A spec rear beam
Figured you might be interested in my rear beam mods... It is stronger and supports adjustable trailing arms... ...
Old May 25, 2008 | 09:38 AM
stage 3 muppet's Avatar
stage 3 muppet
nice lookin beam there pal is it 2wd or 4wd?????
im looking to start making one of these myself with the 6 degree mod and the adjustable rose joints etc . do you have any specs ,measurements etc and did you modify yourself or was it done by someone else??
either way nice looking job pal
im looking for as much info as i can get on beam mods ,can do the grunt work myself ,but getting dimensions and info first is a pain lol
Old May 25, 2008 | 10:31 PM
oohogwash1's Avatar
oohogwash1
It took me a long time to get this sorted. still working on rest of suspension, I have modified trailing arms for coil overs..
I did all the work myself, I have a TIG welder, powder coating setup, my 3 door is totally in bits, you can see the base of the rotisserie in background not even fuel lines left, I have made all kinds of crap. I am using Dick Johnsons car as inspiration as his shop is a few miles from me and he still has his best sierra on show.
The dimensions are somewhere on my computer will look for them, the critical one is to have the front hole 90mm ahead of existing one. Also note that you have little room around the pin hole as you have hand brake line...
Your bolts will be 12mm / 1.2 inch. The rose joints I used are 3/4 chrome moly... Note also that I added strengthening to the side of the mount...
Not sure if you have much else to go by, let me know..
jessie_rs
62
Aug 6, 2019 09:27 PM
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
