ofac and ofab whats the main differance
Old May 24, 2008 | 10:37 PM
gup's Avatar
gup
Default ofac and ofab whats the main differance
as above fellas
ive got a ofac ecu which has a chip plugged in how much boost can you run on these
somone said that i can run at max is 18psi but thats pushing the standard injecters
would i be able to push 16 and hold a bar
Old May 25, 2008 | 09:59 AM
rs gez's Avatar
rs gez
bump as i dont know the differance either......
oh and i have a frst h reg
Old May 25, 2008 | 10:24 AM
gup's Avatar
gup
if im right the ofab is that beter one as if your gonna run say more than 18psi then you can change the map senser to a cozzie one
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
20/20 vision
Sep 28, 2015 03:03 PM
