Help Bleeding rear brakes
Old May 24, 2008 | 02:53 PM
turbocat's Avatar
turbocat
Default Help Bleeding rear brakes
Ive got a 90spec s2 rst It went for a mot last week and failed on nsr brake not working very good. So I took the drum off and changed the brake cylinder. But I carnt get any fluid through it I dont understand why Now both rear brakes dont work when I put my foot on the brakes but the hand brake works ok
Has any one got any ideas why or what Iam doing wrong
Thanks
Old May 24, 2008 | 04:18 PM
B1G_RST's Avatar
B1G_RST
are you bleedning your brakes when the car is on the deck ? the wheels must be on th ground
Old May 24, 2008 | 04:34 PM
turbocat's Avatar
turbocat
1st the whole rear of the car was jacked up but then I did reed that it has to be on the deck have I buggerd something up beacause I tried bleeding it in the air first
Old May 24, 2008 | 11:51 PM
danboy's Avatar
danboy
any ideas why??? i have to take off my drums soon to change the shoes and would like to bleed the fluid threw, but have never heard of having to do it on the ground??
Old May 25, 2008 | 12:05 AM
The load compensators on the back under the rear seat close when the car is off the ground ,suspension related
Old May 25, 2008 | 10:43 AM
turbocat's Avatar
turbocat
The rears still wont bleed any ideas should I get one of them easy bleed kits
Old May 25, 2008 | 12:25 PM
B1G_RST's Avatar
B1G_RST
get a garage to pressure bleed them, thts what i had to do, but i got my rears working was my fronts tht were full of air
sean
Old May 25, 2008 | 05:58 PM
RAT8OY's Avatar
RAT8OY
Sounds like the load compensators at the back have siezed up.
Try taking them off, stripping, cleaning and putting them back on.
If not, you will need new ones.
Old May 25, 2008 | 10:04 PM
turbocat's Avatar
turbocat
You got it in one mate gave them a clean up and heypresto They are all bleed up Great Thanks
yatta
May 21, 2016 10:31 PM
markk
Sep 9, 2015 08:11 AM
kevin36
Sep 8, 2015 12:23 PM
cossirob
Sep 3, 2015 09:17 PM
