Water temps
Old May 23, 2008 | 06:50 PM
Tev's Avatar
Tev
Default Water temps
right whats the average water running temps 4 a cosworth (i know all engines r different) but according to my secs monitor my water temps at the back of my head stays around 80does this sound bout right?
Old May 23, 2008 | 07:04 PM
rapidcossie's Avatar
rapidcossie
sounds about right on an easy cruise.
Old May 23, 2008 | 07:06 PM
charlie luciano's Avatar
charlie luciano
I know that the fans kick in at 87 degrees so it might be static at 80, not too sure though
Luciano
Old May 23, 2008 | 07:58 PM
Tev's Avatar
Tev
yer thats what i was thinkin, its sittin at that temp on the motorway
Old May 23, 2008 | 08:17 PM
rapidcossie
you find that on a cruise water and oil temps are almost idendical due to the modine heat exchanger
Old May 23, 2008 | 08:38 PM
sounds ok to me as long as the fans cut in dont worry about it.
Old May 24, 2008 | 05:59 AM
As glenshute says, ok to me too, shows the stat is working as well.
Oil temps will be higher, why they are cooled by modine, the oil does at least as much cooling as the water.
Old May 24, 2008 | 08:47 AM
Tev's Avatar
Tev
Cheers guys
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
