Electric rear windows stopped working?
Old May 22, 2008 | 06:49 PM
XRT_si's Avatar
XRT_si
Default Electric rear windows stopped working?
As above, on a 1990 Saff Cossie. Checked fuses.
Is it a common problem as my other mates had the same problem years ago?
Thanks
Old May 22, 2008 | 07:00 PM
WongRS's Avatar
WongRS
Probably the window switch, the main one with the 4 switches at the front, mine did it, bought a different one off ebay, job sorted!
Old May 22, 2008 | 07:07 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Does the sunroof leak in heavy rain? Do the drops land in the area of the window switch??
Old May 23, 2008 | 07:27 AM
Does it work from the switch on the back of the centre console ?
If it does most likely just crudded contacts in the front switch, if not need to check for power at the motor etc, could be break in wire from body to door etc, or a duff motor.
Chances are a duff front switch, the contacts have the smallest blob of silver you have seen on them, so take apart and clean up.
You could also add one touch whilst there, so much nicer!!
Old May 23, 2008 | 10:33 AM
TurboShed's Avatar
TurboShed
Cossiemodo
How much aggro is one-touch??
Old May 23, 2008 | 01:31 PM
Piece of piss, about 1 1/2 hours work with soldering iron and 4x mondeo one touch relays.
liam-rst
Aug 10, 2015 08:46 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
