Guages
I am hopefully going to fit a boost guage, air charge temp and oil pressure guage in the centre of the dash where the vents should be.
I am just wondering where I would wire the act guage into, and where I would wire the oil pressure guage to - assuming the oil pressure guage will be electrical.
Thanks,
Thanks,
Oil pressure Sender can go where Switch is, you can get Junctions that you screw in that allow you to have Oil pressure switch + A pressure sensor. Easy work! Just make sure you get the threads right
