s1 & s2 master cylinders
Old May 21, 2008 | 10:25 AM
cressy's Avatar
cressy
Default s1 & s2 master cylinders
are they the same?
Old May 22, 2008 | 02:01 PM
Tim's Avatar
Tim
no pal s2 is much much bigger
tim
Old May 22, 2008 | 08:00 PM
16vzetec's Avatar
16vzetec
s1 23mm i believe, s2 are 25mm and only have two exits for brake pipes as it has abs
Old May 22, 2008 | 08:26 PM
gaz s1's Avatar
gaz s1
i use a s2 item with t peices much better pedal
Old May 25, 2008 | 10:09 AM
moesin2005's Avatar
moesin2005
so gaz do u use the series2 set up with out the abs as i have a series 1 and the brakes are shit
Old May 25, 2008 | 08:23 PM
16vzetec's Avatar
16vzetec
my s2 with t pieces
Old May 25, 2008 | 10:03 PM
gaz s1's Avatar
gaz s1
yes just use the s2 master cylinder with the 2 outlets and run the two pipes to the t peices which then run to your four pipes hope this makes sense ive been on the pop, will post some pics up tommorow
Old May 26, 2008 | 08:03 AM
moesin2005's Avatar
moesin2005
are they piped in on the diagnal say one outlet to the front right and rear left and the other to the front left and rear right cheeRS
Old May 26, 2008 | 07:28 PM
gaz s1's Avatar
gaz s1
yes mate thats how i did mine
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
