Running far too rich...?
Old May 19, 2008 | 04:03 PM
EscortMatt's Avatar
EscortMatt
Default Running far too rich...?
hi, just getting to the last stages of finishing my project - mk 6 Escort with full S2 running gear, but have hit a problem with the running side of things, it starts up fine and runs well for about 10 seconds then starts to run lumpy and when you rev it, it seems to be choking itself with to much fuel. It kicks out quite a bit of black smoke and you can smell petrol in the fumes. Just wondered if anyone can shed some light on this, the engine is fully rebuilt and everything is the same stuff as an S2 except the fuel pump, which is an in tank uprated Fiesta turbo item for the extra pressure needed.... ? ?
Any help, much appreciated.
Old May 19, 2008 | 08:13 PM
Dragsteer's Avatar
Dragsteer
it is impossible to see mixure without wide band lambda. You can make mixure little leaner with CO screw and fuel pressure actuator but without wb lambda cannot know nothing.
Old May 19, 2008 | 08:16 PM
grsford's Avatar
grsford
get it to a good tuner before you do you rebuilt engine harm
Old May 20, 2008 | 05:36 AM
Too much fuel pressure by the sounds of it.
Try disconnecting the 5th injector first, as these can fail,and stick open, but yes it defo will need sorting properly emissions wise.
Old May 23, 2008 | 07:41 AM
EscortMatt's Avatar
EscortMatt
Thanks for the replys, i think the problem could be that the pump might not be suppling enough pressure because the standard EFi (Fiesta) turbos run at 3 bar standard and the MFi's run at 5 bar, maybe even though it's an uprated pump it might not be upto the job of getting enough pressure there... ? ?
If anyone knows if my suspicious are correct and any help would be much appreciated.
Cheers.
Old May 23, 2008 | 07:09 PM
scortpower's Avatar
scortpower
i dont think thats the case mate , i am running a uprated fiesta pump in my mk5 and not having any issues with fuel pressure
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
