head light choices
Old May 18, 2008 | 02:52 PM
v man's Avatar
v man
Zee Germans are coming
Default head light choices
right a bit of a vote here
standard
standard with hid kit
quads
quads with hid
what you all think as i dont know what to choose
Old May 18, 2008 | 05:22 PM
STD + HID.
Old May 18, 2008 | 05:31 PM
KSA-Cossie's Avatar
KSA-Cossie
Std + hid,but it will fook up the display on the dash iirc the headlights bit will illuminate all the time.
Old May 18, 2008 | 06:06 PM
Just put in a 25K ohm resistor, and it will prevent this from happening.
Old May 18, 2008 | 06:08 PM
KSA-Cossie's Avatar
KSA-Cossie
Really ? Where do you put the resistor m8 ?
Old May 19, 2008 | 03:55 AM
In the feed from the relay in the fusebox, ie the dip AND the main beam wire(so need a few), so long as the lamp failure module senses a LOAD, ie enough current passing it is happy, they are only basic REED devices in the lamp failure module.
It is the lack of load that causes the light(failure) to illuminate, I have it when relaying the lights as well.
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
cozzzzy power
Sep 4, 2015 08:14 AM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
