steering fault?
Old May 18, 2008 | 12:50 PM
fezzanut's Avatar
fezzanut
Default steering fault?
my fiesta rs turbo is all over the roads at high speeds 60mph plus.its nearly impossible to keep it where i want it to go its like it has a mind of its own.when turning the steering round a steady gradual bend on a dual carriageway or motorway etc its like a delayed reaction from the steering then massive amounts of oversteer trying to force me alot further across than needs be resulting in me snaking the steering wheel trying to keep it straight again.i have given the front suspension a visual check and all seems ok.thanks!
Old May 18, 2008 | 08:37 PM
groomers's Avatar
groomers
have you checked your lower arm bushes with a lever bar, also the turbo arms are longer than std ones and aftermarket suppliers only list one arm so you may have wrong arm on one side throwing the alignment out?
Old May 19, 2008 | 03:44 AM
As said check rack, bushes(back and front) tyre presssures, geometry, shocks.
tankybaby66
Feb 6, 2016 02:24 PM
IainRS1700T
Sep 25, 2015 06:44 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
