Well been working on the car, and found a wet drivers floor, I have checked the sunroof and windows and cant see any leaks, does anyone know how the floor can be so wet ?
just sorted mine out as it was doing the same.i found the hose to the matrix wasnt tight and the water was leaking out n running into the car,are you losing any coolant
Car has not been ran for over 2 years, its been a work in progress (when i get time)
I think the fuse box will need welding, it it easy to take apart/move ? I may even give the Battery tray a once over.
Can i buy a new heater matrix ? or would it be a second hand part.
