Removal of the Rear trims on the quarter panel
Old May 16, 2008 | 06:12 PM
RS Juto's Avatar
RS Juto
Default Removal of the Rear trims on the quarter panel
How do you remove the rear black plastic trims on the quarter of a saff. The ones next to the rear screen. Mine are showing signs of ageing so i thought i would freshen them up with a coat of satin black
Cheers all
Old May 16, 2008 | 06:15 PM
BigErn's Avatar
BigErn
remove the c pillar trims from the inside mate, they have 2 screws in and clip off. You also need to remove the rear shelf by undoing the screws and pull the shelf forward to release it from its clips under the rear screen. You will then see 3 plastic nuts on the inside for the outer trims. Undo them and Bobs your uncle and all that.
HTH
Old May 16, 2008 | 06:23 PM
RS Juto's Avatar
RS Juto
HTH
Cheers BigErn, thats tomorrows jobs sorted then
Old May 26, 2008 | 11:15 AM
KSA-Cossie's Avatar
KSA-Cossie
Get carbon fibre ones m8.
Old May 31, 2008 | 01:50 PM
boost mad's Avatar
boost mad
From where ?
Ive been looking for somewhere to do me carbon vents too
3drRich
Sep 13, 2015 07:32 PM
Aug 29, 2015 08:16 PM
cos4ever
Ford Escort RS Cosworth
Aug 26, 2015 10:05 PM
paceo
12
Aug 4, 2015 08:50 PM
