Cosworth Abs Problem????
Old May 16, 2008 | 01:42 PM
IANS2RST's Avatar
IANS2RST
Default Cosworth Abs Problem????
my sapphire drives fine, brakes work fine. abs light comes on on start up & goes out nearly straight away. abs light comes on though when I take it past about 130 mph ( on a track obviously)
any ideas?
was thinking that a sensor resistance may be slightly off but not enough to show up a big enough speed difference to put the light on until i get to about 130.
all sensors have been cleaned etc any other ideas appreciated
Old May 16, 2008 | 02:27 PM
ECOS95's Avatar
ECOS95
Mine would come on at 90 on my private test track, it was down to a damaged pickup ring on the OS CV joint. Remove the ABS sensor & using a torch you should see the toothed ring. A couple of the teeth on mine were bent over.
Replaced the joint & no problems since.
Old May 16, 2008 | 02:36 PM
IANS2RST's Avatar
IANS2RST
cheers for that, thinking about it it was working fine up till replacing the complete front passenger side hub assembly & shaft
original
Jan 30, 2022 08:20 PM
moesin2005
Jan 23, 2022 06:28 PM
rdvil
Aug 15, 2015 12:11 PM
Aug 14, 2015 07:29 AM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
