i want more chatter...
Old May 15, 2008 | 09:12 PM
Moonstone Mo's Avatar
Moonstone Mo
Default i want more chatter...
as the title guys i want more chatter as oposed to the dump vale hiss.
i have a 4x4 sapph cossie runnig stage one turbo,360 and cut backs,dark greens-31 actuator,3bar map and a stainless steel.
question is running the car at 20psi is it a must i have a dump valve or can i just get rid of it.car dosent see track but often gets opened up on private race tracks
Old May 15, 2008 | 09:16 PM
KSA-Cossie's Avatar
KSA-Cossie
Ditch the dump valve and fit a massive cone filter m8.
Old May 15, 2008 | 09:18 PM
Moonstone Mo
so i will be ok running 20 psi without a dumpy?? group a cone filter on the way!!
Old May 15, 2008 | 09:19 PM
Moonstone Mo
oh wats needed if i take the dump valve off,is there much to it?
Old May 15, 2008 | 09:20 PM
KSA-Cossie's Avatar
KSA-Cossie
Just blank off the hole m8.
Old May 15, 2008 | 09:22 PM
Moonstone Mo
think im gona do just that my girlfriends brother has just bought one and the chatter sounds lush!!!!cant get enuff of it..lol
Old May 15, 2008 | 09:28 PM
focuschivvy's Avatar
focuschivvy
i was racing a saph on sunday, i had my window open on a nice sunny day with it chattering its bollocks off right next to me....
i could play with myself over that noise
Old May 15, 2008 | 09:30 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
It will be fine withotu a dump valve
Moonstone Mo
lol me 2
Old May 15, 2008 | 09:32 PM
J1mbo's Avatar
J1mbo
B1mbo
why would you need a cone filter any difference ?
Old May 15, 2008 | 09:35 PM
JamesH's Avatar
JamesH
Blank off the vacuum hose too
JamesH's Avatar
JamesH
It has been known to make a huge difference
Old May 15, 2008 | 09:37 PM
focuschivvy
can somebody give me a definition on what causes chatter?
from what i think *i stand to be corrected*......without a dump valve, excess air cant escape, so forces its way back into the turbo causing the shaft to spin the way its not suppost to?
Old May 15, 2008 | 09:41 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
not spin the wrong way as such, just stall
Old May 15, 2008 | 09:45 PM
focuschivvy
so...... a bit like somebody sticking a broomstick through the front wheel of your bicycle while riding it fast
Old May 15, 2008 | 09:49 PM
Jay,'s Avatar
Jay,
Sponsor
yes but u miss out on a nackered spleen and 6 broken ribs but ur turbo will shit its bearings quicker
Old May 15, 2008 | 09:52 PM
rst in breaking's Avatar
rst in breaking
i found the angle of the hose changed the sound of the chatter
Old May 15, 2008 | 09:55 PM
SS1's Avatar
SS1
http://www.wrc-cosworth.org/tech/tur...bocharged.html
Old May 15, 2008 | 10:11 PM
Sexy-RS's Avatar
Sexy-RS
Love chatter Mine is stupid loud! lol
Old May 15, 2008 | 10:23 PM
Stu.H's Avatar
Stu.H
Mines louder
Old May 15, 2008 | 10:51 PM
Red16's Avatar
Red16
because the chatter sound is coming out from the air filter, if you still run the car with standard air filter and airbox it will be quietened by that set up compared to if you are running with a large induction kit.
Old May 15, 2008 | 11:20 PM
SS1's Avatar
SS1
if you get the pedals right .... you can scare people at bus stops
WTF WAS THAT ...,.
Old May 15, 2008 | 11:37 PM
percybigun's Avatar
percybigun
Twistin me melon man
so is it better (for the turbo) to be using a dump valve when running 19-20psi, i get some chatter on mine but was thinking of trying it without the DV to have a listen to more chatter
Old May 16, 2008 | 07:26 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
I havent used a dump on mine since i ve had it and see my sig for my peak boost figure
Old May 16, 2008 | 07:41 AM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
i dont think turbo stall is that detrimental to the life of the turbo. all cars chatter to some degree (even my Golf Gt tdi chatters), the cone filter has a larger surface area and is less restrictive, ie it doesnt damper the chatter noise like a standard set up.
obviously pushing 20 psi through will shorten the life anyway compared with standard boost. i say enjoy the chatter and when the turbo does pop its a good excuse to get a better one
Old May 16, 2008 | 07:28 PM
Moonstone Mo
ha..yeah this one is pretty new last one gave up the ghost
Old May 16, 2008 | 07:30 PM
Big G's Avatar
Big G
Get yourself a 16 year old skiprat, feed her some speed and 4 bottles of blue wkd and you'll have a lifetimes chatter in 1 night, and a blow job if your really unlucky
Old May 24, 2008 | 12:04 AM
Sexy-RS's Avatar
Sexy-RS
Originally Posted by Stu.H
Mines louder
Wanna bet? Mines a hell of a lot louder than alex's used to be be now and that was crazy loud as it was lol
WTF WAS THAT ...,.
Yeah do it all the time had an old man grab his wife and pull her in the bush before as if they was about to get shot
Old May 24, 2008 | 12:21 AM
SS1's Avatar
SS1
my g/f son calls it nitro boost bless him..
even with the iirc dump valve.my car chatters very loud on 13 psi
i guess its not a chave thing. as the old owner fitted it for a reason
but i do have.HKS EVC V Boost control system on the dash. 3 levels of boost(14/24/34), each setting fully adjustable
Old May 24, 2008 | 12:40 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
WTF WAS THAT ...,.
Done this loads
Old May 24, 2008 | 08:42 AM
cossiegreg1's Avatar
cossiegreg1
dump valve is needed when using t4 isnt it?
Old May 24, 2008 | 10:51 AM
alan12112's Avatar
alan12112
Focus St mk2 310 bhp :D
Can you make any turbo set up chatter then?
Old May 24, 2008 | 10:52 AM
JjCoDeX75's Avatar
JjCoDeX75
If you want more chatter, take my wife with you every where you go. She can talk the hind legs off a donkey!
JJ
Old May 24, 2008 | 12:19 PM
BigErn's Avatar
BigErn
Leave it alone Greg
Old May 24, 2008 | 12:21 PM
Dicko&Vacant's Avatar
Dicko&Vacant
yes from what we were led to believe, we had loads of chatter still though, had a spec-r dump valve but it wasnt that loud
Sarah
Physio's Avatar
Physio
The chatter on my esc cos is awesome - proper loud
Old May 24, 2008 | 12:23 PM
Dicko&Vacant
my octavia doesnt even dump or even sound like a turbo
i want some chatter
Old May 24, 2008 | 12:26 PM
BigErn's Avatar
BigErn
Your a woman, you chatter enough as it is
Old May 24, 2008 | 12:33 PM
Dicko&Vacant
dont you know it ian
Old May 24, 2008 | 04:57 PM
cossiegreg1
Originally Posted by BigErn
Leave it alone Greg
i wasnt talking about mine i was just saying.
Tbh the grey one doesnt have a dump valve, and im sick of the chatter, so it makes a change to hear the dump valve on the blue one
