General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Bore Size and pin size will be in the cosworth manual, but i dont have it to hand at the mo...not sure if the other info will be readily available though.
cylinder bore size is 90.8mm...so if you know the piton to bore clearances as standard then you can work it out, i can't remember it though lol.
