Can injectors stick open?
on my clio it's single point injection, and literally it's pumping loads of fuel into the inlet, anyone heard of this on anything else?
i've had multi-point systems have a faulty injector and cause a missfire but never worked on single joint before?
any advice?
any advice?
yeah see thats where my diagnostic skills draw a blank!
it's pretty basic on the clio with just a map senser, throttle position, iscv, temp senser, injector, crank senser.
tps, map, iat & injector is all on the injection unit itself so am going to replace that first and then map/ecu.
vacuum pipes are all good, wiring appears all intact and good, any further advise?
To see if the injector is mechanically sticking open you could disconnect the wiring/plug to it then run the fuel pump (short the relay/direct feed to pump). If it is mechanically sticking open there will be fuel flow from it.
As said above though it could be a number of things that are causing it to overfuel.
SMILER258
Sep 28, 2015 09:04 AM
