How can i tell........
Old Feb 3, 2004 | 07:23 PM
Dave McB's Avatar
Dave McB
Default How can i tell........
what injectors im running??
I aint owned a ford for a while (a couple of dark vaux years) and i been told that me saf cos is running greens, but how can i tell without lookin at em?
Old Feb 3, 2004 | 07:31 PM
stevedohc16v's Avatar
stevedohc16v
Just look what colour they are m8 if they are greens they are coloured green!
Old Feb 3, 2004 | 07:32 PM
B11GNS's Avatar
B11GNS
Whats to stop you looking at them?
Old Feb 3, 2004 | 09:42 PM
Dave McB's Avatar
Dave McB
I looked and they seemed light blue around the top area. The guy I bought the car from said it had greens and im now wondering if he was wrong, or im colour blind
Old Feb 3, 2004 | 10:30 PM
plater's Avatar
plater
The colour they are is what they are, if you get my drift. If yours are light blue then that's what they are, Light blues......... and the bloke who said it ran greens was lying..........unless he painted the 803's light blue
Old Feb 4, 2004 | 12:42 AM
is it a 4x4?
and are they def light blue not dark blue?
what colour is your map sensor? if you were running 803's it would have a 3bar map sensor which is grey in colour.
if your map sensor is black then shes standard mate!
Old Feb 4, 2004 | 05:50 AM
B11GNS's Avatar
B11GNS
Could they be a light green colour, if so they could be 355's which are quite rare nowadays and are between standard yellows and 803 'dark' greens. What sort of boost/power are you running?
Old Feb 4, 2004 | 05:42 PM
Dave McB's Avatar
Dave McB
Its a 2wd, and tthey are either light blue or VERY light green (il get a better look in daylight)
It only runs about 12psi (0.8bar?)or so just now.
I imagine the power to be about 240 or 260, not that much above std.
Where the fcuk is the map sensor? Il tell u the colour once I find out where it is......
Old Feb 4, 2004 | 07:23 PM
B11GNS's Avatar
B11GNS
Sounds like light greens m8, the map sensor is located under the header tank mounted on the inner wing. It is mounted upside down on a bracket
Old Feb 5, 2004 | 10:16 AM
Dave McB's Avatar
Dave McB
Jus checked and its only a 2bar map sensor
Ach, whats another 500 quid for tuning anyways......
