Amal Valve
Old May 13, 2008 | 09:31 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default Amal Valve
What would happen if the hose that goes to the turbo from the Amal valve was plumbed to the actuator and vice versa?
I cant rememebr which way round they go and I cant see any leters on my Amal valve (C, W, or R).
Is it the top hose that goes to the turbo or the middle one? (bottom one is still plumbed to the metering unit)
Thanks!
Old May 14, 2008 | 02:35 PM
Dragsteer's Avatar
Dragsteer
If you connect hoses wrong, boost will be same as amal valve is fault. about 0.3 bar or 4 psi.
Save this photo
http://i115.photobucket.com/albums/n...6eafd273-1.jpg
Old May 14, 2008 | 03:36 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Thanks for that photo, just what i needed!
Although I have tried the hoses round both ways and the car boosts fine...... strange!
Old May 14, 2008 | 06:12 PM
RS16iDale's Avatar
RS16iDale
very helpful pic
Old May 15, 2008 | 03:38 PM
Dragsteer's Avatar
Dragsteer
I have two rs turbos and both of then have wrong connected hose on amal valve. and both cars boost 0.3 bar. when I recconect amal like on photo, boost is normal.
I mean, hose which must go from turbo to "C" on amal valve, ex owner connect it to W.
Karlos: If I am you, will get one amal from friend just to try, because maybe someone "work" on your valve and maybe valve dont do they work...
Old May 15, 2008 | 08:34 PM
Karlos G's Avatar
Karlos G
Balls Deep!
yeah maybe i will try a new one, just out of interest.
Thanks!
steve.rst
Mar 15, 2016 08:01 AM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
rs_jim
Sep 19, 2015 08:41 PM
