Nothing wrong with ITG, used them on DHLA's years ago, they just use a different filter media, but work really well, just need oiling more often.
Well I just need one for my T3, but the smallest I have seen is T34. If anyone has got one for T3 just tell me. I do not need the hose tho, only the cone.
as far as i know they ontl come with 70mm (inlet dia) trumpets so you need to get a new hose that steps up to 70mm, or get a 70mm elbow hose and cut a small ring off your existing hose and out that on your turbo first then slid on the 70mm hose either which will work fine.
and those stainlesssteel filters esp/quickshift, anyone has a positive/negative expierence with those?
( i fancy the idea of not having to oil the filter anymore )
