Saff lights not working.
Old May 12, 2008 | 01:08 PM
Ridgey's Avatar
Ridgey
Default Saff lights not working.
The headlights and rear lights are not working on the Saff. Any ideas what this could be ??? relay?
The indicators are fine and the rear number plate and dash lights all work.
Old May 12, 2008 | 01:27 PM
BigErn's Avatar
BigErn
Maybe something as simple as fuses? Have you checked them?
Old May 12, 2008 | 01:31 PM
Ridgey's Avatar
Ridgey
Should of said, fuses in fuse box are OK.
Old May 12, 2008 | 02:19 PM
The dash lights and number plate lights are fed from one side of the sidelight circuit, so one side should work.
So out with the metre first, as you know you are getting 1 power FEED at the light switch stalk.
Therefore at least one side of the sidelight circuit is fine, assume the front sidelight on the good side works as well.
You may have just got a few blown bulbs, odd but it does happen if the alternator spikes as they can do, only ever had it once myself on a mini, blew the headlight bulbs but no others!!
I would check for power at the front/rear side tailights, then look for a FEED to the stalk from the ignition, that is ONLY live when the ignition is in position 2, as if this is missing the HEADLIGHTS will not switch on, this is what prevents the lights from accidentally being left on when you switch the car off.
Old May 12, 2008 | 02:46 PM
Ridgey's Avatar
Ridgey
followed you reply half way through, then got lost.
As far as i could see, no sidelights or main beam worked. I'll have a look tonight and do a few tests. And look for what ever relays there are for exterior lights
Old Apr 21, 2014 | 08:33 PM
robbie505's Avatar
robbie505
Originally Posted by Ridgey
hi did you sort this out having the same problem with mine after a rebuild
Old Apr 21, 2014 | 10:19 PM
jon@work's Avatar
jon@work
check the big module behind the dash is plugged in correctly
Flatlinedan
Sep 18, 2015 12:41 PM
Cossikev
Sep 13, 2015 02:00 PM
The Enigma
Sep 12, 2015 10:12 PM
fuzzy
Sep 4, 2015 10:11 PM
