Turbo damper
Old May 8, 2008 | 07:15 PM
BRAMMER's Avatar
BRAMMER
Default Turbo damper
How the hell do you fit them???? as i have nothing to connect it to at the turbo end
Old May 8, 2008 | 07:30 PM
AndyPen's Avatar
AndyPen
Whats the turbo mate? 2wd cars had damper plates mounted on the turbo but not sure about 4wd cars??
Old May 8, 2008 | 08:12 PM
DD's Avatar
DD
4wd cars don't have the bracket, its and 'A' shaped bracket with a hole at the top.
Old May 8, 2008 | 08:17 PM
BRAMMER's Avatar
BRAMMER
It's got a T34 on it.
Old May 8, 2008 | 09:06 PM
AndyPen's Avatar
AndyPen
Look at my T4 on the left and on the top right you can see a bit of a plate sticking up where the bracket would fit.
and going into the car the same system is being used...
... so I guess you need a mounting plate but I'm afraid I'm not familiar with your turbo - anyone else help on that score?
Old May 8, 2008 | 09:13 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
As above. you need a new C clip that holds the turbo snails to the core, and has a hole in it for the hanger, like so:
Old May 8, 2008 | 09:44 PM
BRAMMER's Avatar
BRAMMER
Right, where can i get one of these from???
Old May 8, 2008 | 09:47 PM
Chip's Avatar
Chip
Cr turbos
Old May 8, 2008 | 10:34 PM
BRAMMER's Avatar
BRAMMER
Been on the site but doesn't give any info about parts, what sort of money do these go for???
Old May 8, 2008 | 10:36 PM
Chip's Avatar
Chip
Its only a flat piece of metal, nothing fancy, so cant imagine it being much.
Give CR a ring, im positive they can sort you out, they probably just dont bother to list it on the site.
Failing that, im sure someone will have a secondhand one you can have?
Old May 8, 2008 | 11:17 PM
BRAMMER's Avatar
BRAMMER
Cheers mate i'll call them 1st thing
Old May 9, 2008 | 05:31 AM
JanDK's Avatar
JanDK
or like this... these are still for sale.
https://passionford.com/forum/ford-sierra-sapphire-rs500-cosworth/235999-how-mutch-intress-are-there-for-t3-brackets.html
Old May 9, 2008 | 05:45 AM
You can easily flatten a actuator holding bracket to do the same thing as well.
Old May 9, 2008 | 05:12 PM
BRAMMER's Avatar
BRAMMER
Got one sorted £20 posted from CR Turbo's
Old May 10, 2008 | 10:28 AM
AndyPen's Avatar
AndyPen
Good news mate
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
