How Do You Check Wear/Damage To Hydraulic Tappits??
Old May 8, 2008 | 03:46 PM
MJ_RST's Avatar
MJ_RST
Default How Do You Check Wear/Damage To Hydraulic Tappits??
As title,
Took the rocker off, in the process of replacing the head gasket and looked at the hydraulic tappits, but need to know, if one (or more) is faulty What sort of physical things should i be looking for?? and is there anything to test whether each one works??
cheers
Old May 8, 2008 | 05:46 PM
instain's Avatar
instain
release the lifter if its under pressure and push down on them if they feel like they go down there no gd lol the way i work it if they tap there fecked but watch out cause acording to ford there is different types as i found when i got sold the wrong set and the got chewed up in the head
Old May 8, 2008 | 05:58 PM
It is next to impossible to test like this, if they have done any amount of miles just replace them, or if any were noisy.
Old May 8, 2008 | 06:11 PM
MJ_RST's Avatar
MJ_RST
yeh i had just figured that i would replace them anyway, as there was a fair tap off the top end
i had been told that they could be replaced individually
Old May 8, 2008 | 07:59 PM
They CAN be replaced individually, then you might have to play hunt the noisy one again!!
dojj
Sep 29, 2015 10:32 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
